1 - 12 of 12 Posts
325 65 18s? I test fitted 325 60 18s with no issues other than they rubbed my upper control arms a little on turns. I even tried 295 70 18s (34.5 by 11)with my pwm and they worked. (My pwm is trimmed pretty far) I think with a ton of trimming you might be able to squeeze them in. But you could rub the frame with a wheel spacer. plus the 04-07 titans don't have the height stock that 08+ titans have. My RC 3 in had the old style ucas and I changed wheels to a zero offset because the 325 60 18s rubbed the ucas. I ended up settling on 305 65 18s and they fit the truck nice. 33.6 by 12
That and any type of binding in the front suspension. Like mine would do it if I backed down in my drive way while turning
Just put them on, you've already made up your mind to do it anyhow.
You'll most likely hit frame with either setup. Every truck is different so you might be one of the very few to get them to fit without any rubbing on the frame, but you'll have to cut the crap out of the pinch weld.
You also posted in the 2016 section.
1 - 12 of 12 Posts
