That's about the max width I'd go on that rim... I'd be more worried about the height. They *might* fit, but it'll take a LOT of cutting. Wait for norcal to chip in haha
Sounds like BS, but I think it's possible. Although maybe his alignment wasn't set correctly after the leveling kit was installed. This gives some additional lift as well as additional tire wear. At $1k + for tires, it's worth getting an alignment. Also, if dag88's caster is set so the wheels are more forward than most Titans, additional pinch weld and mud guard clearance will exist.Not to be rude, but I don't believe you. Let's see some pics
The '10 2wd can take a 2" leveling kit, the newer 4x4's have the 1.5" recommendation. Pics at full lock would be nice.You should have a lot of coilbucket contact too, the max spacer for a 2010 is 1.5"... Go advanced, there's a button that says manage attachments
All true. But the reason people get away with the wider tires on the narrower rims and often have good tread wear too, is the broad range of inflation availble, especially when used on a 1/2 ton.^Stock wheels fit a lot different than aftermarket wheels, their high offset helps keep your wheel and tire tucked into the deepest part of your fenders. It should be easier to fit a 35" tire on the stock wheels over an aftermarket wheel because of this but this doesn't come without sacrifice. Even if you hack the truck up to make them fit the stock wheels are too narrow for a 12.50" wide tire. The tire will wear out quick and has a higher potential for failure.
My suggestion it if you are staying with stock gears, stay under 34". If I had 18's I would run one of these ... BFG A/T KO 33.7" LT305/60R17 or Toyo M/T in a 33.6" LT275/70R18, (with BT gears). For any stock geared Titan, the 33" LT295/65R18 GoodYear DuraTrac, the 33" LT325/60R18 Kumho KL78 A/T, or the 33x12.5R18LT Toyo M/T. Toyo M/T's and Nitto Trail Grapplers are very tough but also very heavy, so with gas prices what they are, the DuraTracs would be the likely pick.So what would be a good size to go with? I want a wider tire than the stock 165/70-18's. I would like an aggressive looking tire like the trail grappler.
Sent from my Autoguide iPhone app
4" bracket lift kit minimum. That's all you need to know.So if I take my stock 08 SE 4x4 Titan and I wanted to put 35s on. What is step by step what I would need to do? Because I am so confused
