was wondering if with a procomp 6" lift, PRG coilovers with spacer and upper control arms and add-a-leaf 3" will i be able tofit 37" tires...or do i need a body lift.
also how big of a customs spacer can fit ontop of the prg coilovers with upper control arms? 2-3"?
PRG mfg's a spacer that is less than one inch (.87 I believe)...if that helps at all. If you are 4x4 the CV angles are your biggest concern in terms of stretching the front end height.
Fox Delta ran 37x13.5R17 Toyo M/Ts on the stock OR 17x7.5" rims with a PC and coilovers. They looked good. Aftermarket rims would probably require some trimming, and maybe more lift.
Vendor
What he said...it all depends on what wheels you're running...
It can be done, but you have to be sure to get the correct BS on the wheels. I have heard that 37's will fit with that setup with a 5 3/8" BS wheel like the American Racing Thugs...
