will I pass emissions in New York with Long tube headers and catted bpipes?
3376 Views 3 Replies 4 Participants Last post by  LUBECAKES
Moving to New York (Rochester) in a couple months and I have JBA long tubes, cajun catted bpipes and Jba catback. Read this and not sure if I will have to have the "Low enhanced" visual part of the inspection..?? Anyone in upstate NY. have any problems?
EMISSIONS INSPECTIONS FOR CARS AND LIGHT TRUCKS
On-Board Diagnostics Generation II (OBDII) Inspection. Most 1996 or newer gasoline-powered vehicles and most 1997 or newer diesel-powered vehicles that have a gross vehicle weight rating (GVWR) less than 8,501 pounds are subject to the OBDII emissions inspection. This test examines the Malfunction Indicator Lamp (MIL), also known as the "check engine" light, for operation/illumination, and verifies the test results of the vehicle's "on-board emissions diagnostic" system.
Low Enhanced Inspection. A "Low Enhanced" emissions inspection is required for most other vehicles, unless they are subject to the OBDII test or are exempt from all emissions inspections. This inspection is required for all vehicles from and including model year 1995 and older, through and including vehicles that are up to 25 model years old, and that weigh 18,000 lbs. or less.
Each emissions inspection for gasoline-powered vehicles confirms the presence and connection of the vehicle's required emissions control devices. This includes making sure that the vehicle's gas cap is present, is in good condition, and fits properly.
The following emissions control devices are examined if the vehicle was originally manufactured with them:
Catalytic converter (CAT)
Exhaust gas recirculation valve (EGR
Positive crankcase ventilation system (PCV)
Air injection system (AIS)
Evaporative emissions control (EVAP)
Fuel inlet restrictor (FIR)
Thermostatic air cleaner (TAC)
-Mike
Cajun Stage 1 and 2 has passed NY emissions several times.
Reactions: 1
Earlier this year, I did bring my armada to a local shop in the city. The only reason the shop almost failed the inspection was because the tech saw my DIY wrap on the passenger side-rear axle outer boot. Luckily, I had the Nissan OEM replacement boot kit with me. I showed it and explained to the tech that I do 99% of the maintenance/repairs on my armada.
Otherwise, I haven't had any issues passing emissions in NYC for the last two years running Uprev, JBA LT and PRT catted b-pipes.
Reactions: 1
As long as there are no codes you'll be fine.
Reactions: 1
