I've found some wheels and tires for my stock 05 XE 4x4 Non-OR to replace the steel wheels and worn tires that I like and just wanted to be sure they would fit correctly.
The rims are 17x8, Offset: 25mm, Bolt Pattern: 6-139, Rec. Tire Size: 285/70-17, Weight: 26.5lbs.
The tires are Bridgestone Dueler A/T Revo's in 285/70TR17.
Also, what would be the largest tire I could run at stock height without any modifications?
Thanks for your help!
