Wire locations?
3564 17
Anyone know where I can tap into the speed sensor wire and the reverse wire? Ive looked just about everywhere. The truck is in pieces and I would like to get it back together tonight. Haha
1 - 18 of 18 Posts
Maybe I should send you the Titam manual to you. Theres too much on here unless you know what you are looking for. PM me so I can send it
DIRECTWIRE™ WIRING INFORMATION - NISSAN / TITAN / 2006 / Accessory
[PRINT THIS PAGE]
12volts green (40A) + ignition harness
Ignition black/red + ignition harness
Parking Lights+ red/blue + dimmer switch on dash
Parking Lights- N/A
Headlight blue (L), red/yellow (R) + IPDM E/R, brown 8 pin plug
Notes: The IPDM E/R (Intelligent Power Distribution Module Engine Room) is in the right rear corner of the engine compartment, behind the battery.
Trunk/Hatch Release N/A
Power Sliding Door N/A
Speed Sense white/red 8P cluster or shift lock control unit
Notes: The shift lock control unit is behind the glove box, to the left.
Also found at the AV switch on vehicle with the midline and premium audio systems.
Wipers blue (L), blue/black (H) + IPDM E/R, brown 12 pin plug
LF Window up/dn green/red - green/white A LF window switch in door
Notes: Extended triggers on the door lock wires will also roll the front windows up/down. Use validity channels to control.
RF Window up/dn blue - green A RF window switch in door
LR Window up/dn red/yellow - red/black A driver kick, door harness
RR Window up/dn blue - red A driver kick, door harness
Sun Roof open/close motor part of module
Sun Roof Limit/close N/A
Memory Seat 1 lt. green/black - memory mod. left of column, pin 9
Memory Seat 2 pink/blue - memory mod. left of column, pin 25
Memory Seat 3 N/A -
Interface Module: Category:
Door Lock Interface Required:
No Type:
Data Bus
Part #: XK02
Alternate Part1 #: IM-Nissan-1
Notes:
Immobilizer Bypass Required:
Yes Type:
Transponder
Part #: XK07
Alternate Part1 #: 556UW
Alternate Part2 #: DesignTech 20402
Alternate Part3 #: DesignTech 29402
Notes: Standard on the SE and LE models. Optional on the Crew Cab XE models.
Smart Starter Kill Relays: Not Available
warning
This wiring information is being provided free of charge on an "as is" basis, without any representation or warranty. It is your responsibility to verify any circuit before interfacing with it using a digital multimeter.
Directed Electronics assumes no responsibility with regards to the accuracy or currency of this information. Proper installation in every case is and remains the responsibility of the installer. DEI assumes no liability or responsibility resulting from improper installation, even in reliance upon this information.
Discussion Starter · #16 ·
baseballfanz said:
Speed sensor wire is behind the cluster gauge. Only the LE/SE have the reverse wire behind the passenger kick panel. XE you will have to into the engine bay or back to the rear of the truck.
Is it in the harness that directly plugs into the cluster, or is it in one of the branches of wires that are behind it?
Machado7 said:
BBFan- can he pick up the reverse signal wire as it reaches the rear sonar control unit?
Being that he has an XE I don't think he has the rear sonars. The closest place is probably under the hood near the fuse box(IPDM).
1 - 18 of 18 Posts
