The sub should come with everything you need. You tie into the rear speaker wires at the door sills, so do a search here for the color codes.
It supposedly takes both line level and speaker level inputs, so I don't need a LOC right? Just tap into the speaker wires closest to the sub placement and add power.
That's correct. Pop the sill covers off at the door bottoms and you'll see the speaker wires in a black taped loom. Run the main power line all the way to the positive battery post, and you can ground it with a screw into the door sill. My switched power is at the ignition switch. I forgot all the color codes since my powered sub was installed in early 2006. There are a few threads here somewhere with installation instructions and color codes.
