Hey guys, i bought this 05 last year in November, and it has been a pretty good truck, i love it (other than its 8-10mpg). I just finished putting JBA LT's on it, and while doing so i noticed something. While working on the driver side i bumped the steering shaft with my forearm and it moved? Upon further inspection it moves about 1-2 inches?? Its the shaft right as it comes out of the firewall, i can push it with one finger, and the entire shaft moves.
My truck does have a 3" body lift, and i read somewhere you need to adjust it, but as i went to go loosen up the nut, i found out it had been rounded off??
Is it just this steering shaft needs to be adjusted, or is something broken/worn out?
Ill try and record a video to post for you guys to see.
EDIT: Heres the video.
Loose steering shaft
