I have a 2008 Nissan Titan with 115k miles on it. When i first jump in and start it it will run fine until it warms up and then it wont move at all. It will start jerking and then when i hit second gear it wont go and only the rpms will idle. if i shut it off and turn it back on it will move until i hit second gear again. IF i let it cool it will run great until it warms up and does it all over again. I have already had the transmission rebuilt twice and it is still doing the same thing. Anyone hear of a Titan doing this?
Nope! never heard of this before. Where did you get the trans rebuilt? Are they using Nissan Matic-J/S or equivalent trans fluids?
I would assume that they are. I was told by a couple ppl that i should clean or change my maf and map sensor but i dont see how that would cause this problem. I feel like im gonna have to drop 3g more at another shop. Between all the tows and work i could buy another one
you could have bought a level 10 trans with new torque converter for a little more than 3k. Do you have any check engine a/t trans lights?
