1 - 2 of 2 Posts
My old work truck reared is toast. My truck is a 2006 titan found a used rear emend out of a 2004 but my buddy says transmission will not shift unless it’s from same year. Says the rear ended has a sensor in it. Is this true. I would appreciate the help I really need to get it back on road cheaply
No. You need a rearend with the same gear ratio as your current diff or your cruise may not function. There is no sensor in the rearend which communicates with the trans.
1 - 2 of 2 Posts
