Air bags are great because when you're NOT towing you're not stuck with all that ride killing rear spring rate...
Are those manufacturers dry weights on the 5er? I'd take it to a scale equipped as it would be after being option out as you want it. Manufacturer dry weights always seem to be on a stripped unit and not include battery(s) or propane or things like AC units. You also need to factor in what you plan on loading as it will affect pin weight. I don't mean to come across as preachy and the Titan is a great truck, just it does not match up well with 5ers due to payload limitations.
Go with the Firestone Ride Rite bags. I have them...work great with only 15 psi. Your Titan will pull that 5'er with absolutely no problem. With my heavier load I stayed in 4th gear...both temp. gauges read the same as if there was no trailer in tow.
