They will cause the tires to rub at the pinch weld and mud flaps at least. Narrow 35s can fit with a level kit on stock rims, but not on a 9" wide rim with 4.5" b.s. w/o major trimming, maybe even at other fender areas with 325/65/18s. Consider a 35X12.50R18 instead of a 325, and a 8 or 8.5" rim with maybe a 5.5" to 5" b.s. Still might need a little trimming though.
The bolt circle should be 6 on 139.7mm, (6 on 5.5").
