Can you post a link to this? Cheapest I was able to find them was $70 per spring.rockauto.com $80 for the pair. I was told do the 09 4x4 springs. I am doing the same thing
They aren't longer, they have more coils and a higher spring rate which makes them sag less then a set of 2wd springs. Too bad I was too late. I have a set of 2009 4x4 struts with springs complete for sale for $120 shipped. I also have rear ranchos available.The 08 4x4 springs are longer than my 06 2wd springs, so more travel and lift with the 08 4x4's
You would need to use prg uca's if you put the struts with the leveling kit.hey Aquaholic, are the 09 shocks higher as well? and will they work if i have a 2.5 leveling kit on already? i want 4 inch spindles but would the springs achieve this?
RockAuto - 2009 PRO-4XCan you post a link to this? Cheapest I was able to find them was $70 per spring.
