Just yank the overload spring an buy the shackles from suspension max. That's the set up I have.
Sent from my iPhone using Autoguide
The overload spring holds alot of the tension so when it's removed the rear drops. Then add the shackles and you'll get a 4-5" rear drop.how low does that setup drop the rear??
it depends on what look you want and how much you want spend. i wanted mine to sit level in the back with the front so i just pulled the a leaf out of the leaf pack and its almost dead level. i want it to be lower so im going to wait and get some 24s drop spindles and a flip kitwhats the best way to actually drop a titan
