Nice looking gear. Just FYI you probably won't be able to fit a 15 or 16" rim on a Titan due to the size of the brakes. If your truck is an '08+, then 18" is the smallest size wheel you can run with stock brakes. Good luck with the sale!
Check your build date. I was told that a build date after 03/07 had the newer style brakes which means check the 17" rim b4 installing. Just a heads up.
My truck was made 9/07 (I think) and mine came with stock 17"s.
