1 - 20 of 20 Posts
Curious to know if I can fit the 20" from the 2016 XD on my LE 4x4?
Found some measurements online and from what I have read the offset is different (25mm to 44mm) as well as the width (8" - 7.5")
2005 - 265/70R18*114S 8Jx18 ET25 6x139.7
2016 - 265/60R20 7.5Jx20 6x139.7
Anyone actually try it?
So the backspacing will be .25" MORE on the XD wheel (5.25" vs 5") with same width tire. I think we have enough space to do that as long as you don't go any more and don't get a super wide tire. I can check how much space is between the wheel/tire and spindle/UCA after work today.
Reactions: Spdosnd
I will be running the stock tire size. Have the tired 05 wheels with 180k miles of experience. Just wanting a refresh.
its gonna look super sucked in. might have issues with the tire rubbing the spindle. also might rub the frame when you turn the wheel all the way.
True, your tire will look .75" farther in underneath the fender. May not sound like a lot, but you'll notice it. I can tell the .5" difference on mine from my stock wheels.
So it's safe to assume that no one has tried this yet. Maybe I can get the guy to let me fit them on my truck before I buy them.
no you're right no one has, because a +44mm sounds terrible.
Discussion Starter · #8 ·
I am still trying to confirm the offset. I have read anywhere from 25mm to 44mm with most referencing 35mm but nothing that has been confirmed.
Oh they HIT!! I went and tested them tonight. Looks like I will need about a 1/4" Spacer to make it work. They look great though. Anyone have suggestions on spacers for the Titan?
I also need the same style bolts as the 2016. Any suggestions on where to get those or longer ones like it? (40224-1LA2B)
BORA makes bolt on wheel spacers. the smallest they have is 1".
I don't see how all this is worth the effort for a Stock wheel ;)
Discussion Starter · #11 ·
So now I have the wheels. Just ordered a bag of 24 [40224-1LA2B] lug nuts (hope they are deep enough grab enough thread) and going to test clearance with a 1/4" spacer tonight.
So they might not grab to begin with PLUS you're gonna take an extra 1/4" of threads away by adding the spacers.
Unbelievable. I've been saying this for a couple years....trucks are the new rice.
Discussion Starter · #14 ·
Hey Tootsie, my bad and my bad to the community. Yes I did solve this. BORA offered to make a Titan 1" spacer with 12mm bore for the 1G titan hubs and 14mm studs to mate to the 2G Wheel. This way I can use the 2G wheels and 2G OEM lugs.
BORA quoted $250 for the spacers and I contacted them through FB to special order the items.
I didn't actually pull the trigger on this only because I got a set of 1G 20s and preferred the look.
Discussion Starter · #16 ·
Here is the final result.
YESS!!!!!! That's awesome! Did you use the BORA spacers? How is the offset? Can you take a picture of the profile?
1 - 20 of 20 Posts
