1 - 20 of 26 Posts
Does anybody have any pics of the rockstars on their titan I'm considering those for mine but would like to see them on the Titan first
Here's mine with 18x9's wrapped in 35" KM2's. I've just painted the center stars flat black (not shown in pic) and I think it looks better. Actually, I wish there was an option to replace the entire center cap/cover thingie with a standard cap that covers just the hub hole. Does anyone know if this is possible?
I called my contact at KMC, he said that there were two style caps for the Rockstar. They look the same, but the difference is in how the cap sits on the wheel. I asked him if it was possible to get just a standard cap, he said the cap it came with is the only type to fit it.
those are great I was tryin to decide between the Rockstars or the Moto 951 blacks and Im definently leaning towards the rockstars especially because they have a 5" BS where as the 951s have a 4.5" and I like the way the rockstars look on the titan
Also does the TPMS work with the rockstars?
Discussion Starter · #8 ·
Good to know one more thing will an 18x9 with 35s squeez in with just a leveling kit and a pinch weld mod? Im pretty sure the BS is 5"
I'd have to go with a negatory on that. Even with a 6" lift, I had to trim the pinch weld to prevent my 35x12.5x18 BFG's from rubbing at full turn going up a curb.
Thanks for calling them for me, boondock! Actually, I've the caps for the chrome wheels are closer to flush with the wheel whereas the black ones are about 1-1/4" offset from the wheel face (stupid looking). I cut down the standoff posts so the caps are flush.
I also learned that if the wheel bore (center hole) is 108mm, there is a push-through cap that is available.....unfortunately, my wheels are hub-centric (no clearance between bore and hub). Bummer. I just re-installed the caps after blacking out the center chrome star and it looks pretty good (imo), so I will roll with this setup for a while. I will post an updated pic when I get a chance.
325/60 are the biggest that'll fit with leveling kit.
No problem. My dude actually said to trim the centercaps if you wanted them to sit flush. Post up the pics, and I'll forward them and see what he thinks. He loves seeing people add thier own touches.
This is from trimming 1.25" I bought new bolts just because I wasnt sure I'd have enough threads left over if I cut that much off the originals
Discussion Starter · #14 ·
325/60 are a little to wide for my liking I think ill just go with a 35x12.5x18 thanx 4 you guys' help
That's still a 325 width, dude. 35/12.5/18 and 325/65/18 are pretty much the same thing.
Discussion Starter · #16 ·
half inch diff
Discussion Starter · #17 ·
sorry 33x12.5
Nah, that's just some WD-40 that I sprayed on the oxidized hub face and didn't wipe it down very well. Thanks for the concern, though!
1 - 20 of 26 Posts
