1 - 3 of 3 Posts
2004 & 2012 Nissan Titan Rear
The Yukon Dura Grip provides aggressive yet smooth traction to give you the confidence & performance you need. Get longer life and better traction with the heavy duty Yukon Dura Grip Positraction. The Yukon Dura Grip uses a nodular case and forged 4320 internals for added strength along with composite clutches for high performance and long life. All units are Rebuildable and many offer upgrades to increase aggressiveness for racing applications. Each unit carries a one year warranty against defects.
Includes two carrier bearings and two carrier races from Timken.
Free shipping in continental USA on ground shipping only.
This is a clutch style limited slip.
Duragrip gives traction to both wheels in reverse unlike the Tru-Trac which functions as an open differential in reverse.
Shipping will not be removed from your cart it will be removed once the order is processed by a customer service representative.
I just got this item guys and once I test it better in Baja ill get back to you guys about it.. but it looks really good, well build and pretty much direct swap
Thank you for feedback we would really appreciate that. Hope all goes well for you.
1 - 3 of 3 Posts
