I have been lookng into cars to buy for myself when the time is right for a while. i have started to look at 2007 or newer 350Z's. I really like them, and its between that and a LS2 GTO. Anyway, the reason I started this thread, I was reading about the 2007 350Z differences from the 2003-2006. The 2007 got a more powerful motor (just like the Titan did in 2007). However, the article I was reading said what was the point because it was only rated at 306 in 2007 compared to 300 in 2006 (speaking on the 350z). Seemed pointless for only 6 HP. Thats when I read this " However, the new engine's figures are based on a more rigorous SAE testing procedure. (For comparison, applying the new procedure to last year's engine would probably result in actual variation of about 15-20 hp.). So, in 2007, the SAE testing procedure changed, and it appears then, cars/trucks may have strated reading 15-20HP less then in 2006. I take that if the VVT 2007 Titan had been SAE tested in 2006 or sooner, it would have been released as a 327-332 HP truck. Which IMO, is just about where we all think it should have been rated from the factory
Here's the 350Z article in case anyone cares. that quote is in the first 1 or 2 paragraphs: 2007 Nissan 350Z
