181 - 200 of 214 Posts
Discussion starter · #181 ·
Right now, lower your tire PSI to about 28 and stop flooring it off the line! Ease into the throttle, you are spinning up a hurricane
Thanks for the tip, still new to this :)
Sent from my PC36100 using AutoGuide App
Discussion starter · #182 ·
This is with the new tune, im cooling her down, ill be back.
It takes time, trust me I know. I ran 16.2 and 16.9 in my Titan before I learned to launch it. Go 1/2 throttle then after your rolling quickly ease into full throttle. Takes practice, its not a jerky motion. Thing that is hard to overcome is the nerves
Yea lower to 28 psi. If that font work go to abou 25 psi. Also do a dry burn out. Go around the water and do a 3-4 sec burn out then stage. I just floor it on green. Always worked for me no spinning or nothing when I have the psi at 25-28.
do you have TT? there is no way i can floor it from a dig. all my data logs show im flooring it at about 9-10 mph:crying:
Discussion starter · #186 ·
No tt, i know i know lol,
Yes 08 I have tt. But even before tt all I did was lower the psi on the tires and it would grab.
Discussion starter · #188 ·
Discussion starter · #189 ·
Looking good. Did you lower the psi?
Discussion starter · #191 ·
Yes, but even trying not to peel still peel, Im ordering tt on monday
Sounds good. :)
It'll be lots of fun. I love my tt. Once you get that 60' down you'll run some good times.
Discussion starter · #193 ·
Just killed a lightning , got it on video. Were going again :)
Reactions: import2nr
Discussion starter · #194 ·
01 model
Discussion starter · #195 ·
Got him on the second round also
Discussion starter · #196 ·
The lightning had a rookie driver also, jeje , I talked to the guy and it was his 3rd time at the track, and he said it was jumping to much at launch.
Discussion starter · #197 ·
lightning videos
Discussion starter · #198 ·
second round with the lightning
Discussion starter · #199 ·
with a denali 6.2 stock
Discussion starter · #200 ·
with an SS chevy 6.0 headers and programer.
Reactions: gweasel77
