Long story short, I was hurrying through a brake fluid flush job and... I refilled with power steering fluid. Yep, I'm an idiot. Didn't even realize it until my pedal started feeling spongy and was getting worse.
Done my own research and this is apparently a very bad thing. Rubber doesn't do well in contact with PS fluid. Being that this is the brakes - a sort of important part of any vehicle - and that the Titan's brakes aren't all that great, I am thinking that the wisest thing to do is replace the master cylinder, ABS unit (either/both of these will just be stock replacements either rebuilt or off a wrecked Titan), rubber lines, and calipers. While I am at it I might consider upgrading the rotors and, of course, the pads.
I see all kinds of rotor/pad kits online but calipers are a different story. Only seeing OEM replacements. Here are my questions:
Anyone upgrade their calipers? What (and where and how much $) did you buy?
If you were me, what would you do? Remember, you are me so you are not spending my money, you are spending yours.
