I have 2 cases of it in the garage and was thinking of using it when i change the oil in the titan. Is it too light or should it be alright?
I'm not sure where St Pete is, but sounds like FL or therabouts. I use 0W40 based upon test by JetTech and I'm in mid Atlantic. I wouldn't run 5W20 if in hot climate. Next oil change in Late Dec/Jan might be OK. Mfg are going lighter and lighter, but if 5W20 isn't on the chart for our engine, I wouldn't go that light.titanmike said:I have 2 cases of it in the garage and was thinking of using it when i change the oil in the titan. Is it too light or should it be alright?
I'm a bit confused by your examples. Please clarify or just say yes/no to the following. Thanks in advance.Yahooligan said:Not to nitpick (again.), but the "w" is "winter" not "weight", so 5/30w doesn't make sense.
5w-30 is a 5 "winter" viscosity for when the oil is cold and SAE 30 when hot. Naturally, oil thins when it is heated, so to say an oil flows like a 5 weight when cold and 30 when hot implies the oil is thinner when cold.
5w-30 will flow better than 10w-30 when cold but flow the same when hot. 0w-40 will flow better than a 5w-30 when cold but have a higher viscosity when hot.
:cheers:
YesTitanBlue said:I'm a bit confused by your examples. Please clarify or just say yes/no to the following. Thanks in advance.
Are you saying 5w30 and 10w30 both flow as 30 when hot?
YesThat the 5w30 flows better (is thiner) than 10w30 when cold?
The short answer is yes. A "5w" rating means the oil will flow like a cold SAE-5 oil. SAE 5 oil is very thin when hot, so obviously a cold 5w oil won't flow like a hot SAE 5 oil and a cold SAE 5 oil will be a lot thinner than a cold SAE 30 oil. The cold and hot ratings are typically around 23F for cold and 212F for hot.Therefore 5w is the weight or viscosity of cold oil and 30 (or 40) is the weight or viscosity of the oil when hot?
No. Oil thins when heated, so a 5w-30 oil flows like a 5w (Or cold SAE 5) when cold and like a hot SAE 30 oil when hot (212F). The cold SAE 5 oil will be thicker than a hot SAE 30, which is why your oil pressure is higher when the oil is cold. The higher oil pressure is due to the thicker oil.Therefore, Motor oils start at the thiner (5 or 10) weight when cold and thicken to the (30 or 40) weight when warm?
Yes that it starts out thick, but the numbers are reversed. The confusion comes from thinking the viscosity of "5w" and "30" are both tested at the same temperatures. The cold rating is for a cold oil viscosity, the hot rating is for a hot oil viscosity.Or are you saying just the opposite?
Oil starts thick (30 or 40) and thins out to (5 or 10) when warmed up?
haha, thanks! Oil is interesting...and confusing. I probably got a little confused myself since work was interrupting my thought and typing process for this post.I appreciate pickiness.![]()
This is why (if you've noticed during an oil change), the oil comes from the engine into the pan fairly thick (if the engine is warm) compared to the oil you pour in to replace it from teh bottlem which is comparatively thin.Yahooligan said:Yes
Yes
haha, thanks! Oil is interesting...and confusing. I probably got a little confused myself since work was interrupting my thought and typing process for this post.![]()
Pardon? You're a little backwards there.FuzzyLogic said:This is why (if you've noticed during an oil change), the oil comes from the engine into the pan fairly thick (if the engine is warm) compared to the oil you pour in to replace it from teh bottlem which is comparatively thin.
