17x10 on 33s
2.3K views 5 replies 5 participants last post by  superhawk
I am planning on running 17x10 rims w/5" backspace on 33/12.5/17 Pro comp mud terrains. Wanted input from you guys if the rims would have enough clearance & no rubbing issues on a Stock height Titan, or would i need to at least install a 2" front leveling kit...Please advise...Thanks...
#2 ·
I believe you will have rubbing problems. The 10" wheel will offest the tire centerline out 1" beyond where my 8" wheels (5" B.S.) locate them. And I don't have 1" extra clearance for that to happen when I turn my wheels. I think you will be very close even with the lift.
#3 ·
Thanks for the input...Looks like If I want to run those 17x10s then I may just go for a 6" lift from procomp & run those rims w/35s....Thanks..
