2018 SV Starting Issues - Please Help
11K views 57 replies 19 participants last post by  2018titanSVxd
I’ve reached the end of my patience with my 2018 SV. I’ve taken it to the 2 best mechanics I know and they are at a loss also.
Here’s my issue: truck will start fine several different times in a row and everything seems normal. Then the next start will be nothing but a click. The screen comes on and the radio will play, but it will not crank. If I hit the lock and unlock a few times on my remote and then start it, it will eventually start.
When it does start normally the Bluetooth will only connect about half the time. I’ve disconnect and reconnected the Bluetooth to my phone and my wife’s and still get the same issue.
I recently replaced the battery a couple of months ago. For a week or so it started flawlessly. Now it’s back to the same problems as before. Starter and alternator are both testing fine. I’ve replaced both the break switch and the ASCD switch that are both located at the top of the break pedal that have caused similar issues to other Titan owners.
Nothing is helping. If anyone has any suggestions I’d love to hear them.
#10 ·
that system that you will be disconnecting just turns the alternator on and off, to conserve gas mileage. when you disconnect the "sense" wire, the alternator runs full time, like they did on older vehicles.
there is a long thread on this on the armada forum. some guy who is an electrical dude figured the whole system out and explained how it all works. the sense wire doesn't actually measure the voltage and amps the alt puts out, it just senses if current is going through the wire. the system is set to turn the alternator off at something like 12.1 volts in the ecu so once it sees that, it turns off the wire at the alternator and the sense wire sees no charge so all is good, to the ecu. but you're not charging the alternator fully because your alternator should be charging it to 13.2 volts, which is generally considered fully charged.
unplugging the sense wire lets the battery get fully charged.
#15 ·
that is actually from a first gen titan. the wire you want to unplug is on he bottom of the black box that is part of the assembly that bolts onto the negative post of your battery. there is a flat black thing taht hangs off the negative post and the light grey plug is the one that is your sense wire
Reactions: 2018TitanPRO4X
#16 ·
and no, it won't make your truck have starting issues by unplugging that box. if you already have starting issues, they may continue but if its because of a low battery and your battery recharges to a more full state, it would improve your starting
#22 ·
I ynplugged mine this afternoon, again. I had been watching the battery gauge for a few days to see it go from 11v to a little iver 13v, randomly.
Ever since i took the sense wire off, the battery volt meter has ben sitting dead steady a bit above 13v, ao the battery and truck should be a lot happier
#24 ·
Yup, its a little cool
  • Haha
Reactions: Roush
#27 ·
it should. you guys have the same system, just your sense wire is about 6 inches down the cable from the battery clamp.
#29 ·
i read that a lot on the armada forums, just not only in winter. those guys were having to use battery tenders if they didn't drive it more than almost every other day. disconnecting the sense wire seems to have helped a lot of armada guys
#30 ·
I will be trying it myself next time I drive the truck I will unplug it. I really want it to make a difference in the summer with the AC. When stopped or slow traffic the AC is still cold, but not highway speed cold. I was going to install the OEM Fan a few months back to help move more air at low speeds, but learned my truck is not pre wired for it. So this coming summer I was going to install a 14" - 16" fan with a switch hooked to my AC signal wire.
#32 ·
not from me
#35 ·
I have a 2018 Pro4X…started having the exact same issue over the summer. Battery, starter, and alternator all tested good. I replaced the batter and it went away…until today it happened again. Typically takes about 5 times pushing the start button and a combination of locking/unlocking doors (don’t know if that’s pure coincidence when it does work) then it’ll start.
Very interested if anyone has a fix for this.
#37 ·
I think you are trying a new fix
#38 ·
Have your transmission looked at for a ground loose or needing repair. This happened to me along with a new starter. Hope it helps.
#39 ·
I owned an old Suburban that had a similar issue as the one you are having.
This was back when the trucks did not has all the over the top electronics.
It came to the point that I started replace suspected parts.
Low and behold, as soon as I replace the Starter - the problem disappeared.
So, this story being told... If you come down to your last straw in troubleshooting; Try replacing the starter.
This advise and $6.49 cent will get you a cup of coffee at Starbucks, but I wanted to toss my 2 cents worth into the kettle.
