Hello all,
Last year my passenger side axle started leaking, on the drive to a garage the axle snapped. Turns out the bearing was obliterated and somehow that caused the axle to break. Replaced everything and it ran fine. Last week the exact same thing happened. I noticed the oil leaking, filled it up (took about half a quart) and 20 minutes down the road the axle broke. It's a 2005 with about 120,000 miles (bought used so I don't know the complete history). I had put less than 3000 miles on the new factory axle/bearing/seal.
My question is, what should I do with it? If I just replace it again I have no reason to believe it wont keep repeating this pattern. I've been reading posts about all the rear end problems, not clear what the best solution is.
Any suggestions as to what is causing this, or the best way to prevent it would be appreciated.
thanks-
-Jim
thanks-
-Jim
