4 fills back started to have the gas spurting back out on truck, on ground issue. 3 fills back all fine but then last fill ridiculous. Gave up on filling once had ~ Âľ tank.
Read many of the posts about evaporative solenoid valve, etc. On my Jul.2004 57,000 mi. Titan the valve isn't as easily accessible as it seemed to be stated ... plate below it. So thought, try the easiest thing I found here first. Plus when went to dealer (BJ Nissan N, Houston) parts counter person checked with mechanic and said what you stated was the most likely cause, that they're open to 5 and willing to sell me whatever part I want if this didn't work. Got a varnish-covered coat hanger, cut as close as possible to where winds, used some toluene to remove the varnish coating, then worked one end into the side vent tube opening right side of filler tube, pushing gradually, when felt some resistance, pulled back a bit, rotated wire, back in again now rotating as going along, whenever resistance, repeated as above. Finished pushing and rotating hanger with large pliers in order to get most length through possible.
On the way back from the dealership I stopped by Best Buy and bought a can of 'compressed gas duster'. The tip of the red tube on side of can just reached the filler vent tube opening. Kept doing short bursts until smelled gas fumes ... I assume from the top of the gas in the tank by way of the main fill tube ... gas in the compressed gas can is odorless. So it appears a wire hanger length of wire made it through the curves in the vent valve tube near where it goes into the tank by rotating it while pushing in, pulling out.
Then, off to the gas station to test. Fuel nozzle rubber boot firmly on filler tube opening and gas flowed fine gas nozzle handle pulled to max flow position.
So, a few hours here, a 10 min. drive to, back from dealership, 10 min. or so talking with parts counter person, he with a mechanic, 10 min. stop at Best Buy for compressed gas, 10 min. under truck deciding not to try anything with solenoid valve at that time, go get hanger, cut & clean it, couple min. pushing it through, min. or so with the compressed gas.
Now to get a feel if any of the gunk in the filler tube vent has an effect on truck running, the fuel filter.
I’ve mostly read here that the fuel filter is in the gas tank but also read that it’s in or part of the fuel pump which is on the outside of the gas tank. So I’m wondering where the fuel filter actually is.
Since wire-hanging the gas tank fill tube vent line and driving to and back to fill with gas all is fine so far. Piece of wire and small tool chest in truck at all times now.
