1 - 6 of 13 Posts
Unplug the antenna and see if it's still there. If no, check your antenna and cable. If yes, you have a ground loop or other electrical issue.
Make and model of the head unit?
If aftermarket did you use a harness adapter, or how did you connect it to the factory wiring?
Sorry for all of the questions... What method did you use to connect the Scosche harness to the head unit pigtails?
It's usually because of a bad ground or a bad connection somewhere. Because it only happens on FM I would also suspect the tuner in the head unit.
Did the factory unit also have this problem?
In that case I might even suspect a bad coil or spark plug. When you say ticking it tells me that it's only picking up one coil, if it was all of them it would be more of a hum or buzz.
Reactions: 20TITAN04
1 - 6 of 13 Posts
