621 - 640 of 1,160 Posts
Help me out gentlemen. I'm planning on installing some Pro4x coils and shocks with a spacer that provides 1.5" lift on my 04 4x4. Do you all think I will have CBC even if I grind the lips down? I'm wanting to use my oem UCA's for the time being. Anything out of the ordinary I need to complete this?
Also could someone tell me about how much lift this setup will provide? Thanks
Thanks for all the tips and suggestions.
I have a 2005 LE 4x4 Crew Cab Off-Road Package. I was looking on ebay, (everyone suggested Billet) and found the linked. It mentions that it fits every year 04 - 13, but that it does NOT fit the PRO-4X. Can anyone confirm (or deny) that the Off-Road Package turned into the PRO-4X package, and therefore this will not fit my truck as well?
http://www.ebay.com/itm/14126071359...260713590?item=141260713590&viewitem=&sspagename=ADME:X:RTQ:MOTORS:1123&vxp=mtr
Also, if this will fit my application, will I need the camber adjust bolts to have an alignment done afterwards?
Thanks in advance - I'm a newbie, but love this forum :)
It will fit. There really isn't any difference. I would get the cam bolts so that your alignment is perfect.
I have an 06 titan SE KC 4WD and after reading this awesome thread, I figure I need to start my lift/leveling process by buying the Bilstein adjustable ride height shocks and a 1.5" leveling kit. Then work on the back once I see where I end up in the front. Heres the problem. Cant find any of these things anywhere. Every site I check says the #24-197649 is on back order. Anybody know where I can grab these right now? Ill check the buy/sell as well on here to see if anyone is looking to unload any. Thanks in advance. And again, thank you to those of you who take the time to put out the info Im finding on here.
They are on back order every where except amazon which they are more expensive there... iirc the guys from tap auto said it wouldnt be too much longer... people started buying uo the pro comp adjustable but I think they are now on back order... the billet spacer I got mine on ebay and am happy with it 53 bucks well spent! Good luck on your search bro!
Sent from my Big @$$ phone...
I have been reading a lot of forums about the Bilstein 5100's not sure about my set up. I have a 09 titan 2wd cc. I have a new set of xd's 20x9, 275/60/20, and a set of 5100 front and rear. My plan is to have the front on the middle setting, but I don't plan on having any spacers. Right now I have 35 3/4" in the front and 37" in the rear. So having them on the middle setting should work right? I'm not looking for any negative rake. Just level or a small amount fwd. Any ideas. Thanks
IIRC you will be level if you put the front on mid perch
Middle setting will bring you up an inch, so you will be very close to being level, probably not noticable difference between front and back.
Listen to this guy ^^^
I have a 2011 nissan titan 4wd and put a leveling kit on the front and back. 3" in the front and 2" in the rear. i put upper control arms on because stock ones rubbed but the new ones rub as well. and i also put bigger sway bar links on as well. what can i do to fix this or why is it still rubbing.
What upper control arms did you put on?
If you have the RC arms elly the max you can go is 2.5" up front, PRG and Dirt king arms give you a little bit more room, If you have either of those and still hit, you need to drop your front spacer down another .5 or do some grinding on the lip of your coil bucket where it hits, not recommended, but many have done this without adverse effects, just don't trim too much.
I am new here and have a 2014 SV Crew Cab 4X4. I have owned 2009/2010/2012 Frontiers and have had them lifted. I talked to PRG the other day and I think I have decided on his 3" UCA package. My desire is to lift the front the best way "correctly" so I can and get some skinny 33's to clear easy. I do not see much here on the 2014 models and for all I know they are the same as everything 08+. So far I have the weather tech floor mats :).
Mods planned:
Bug Shield
Bed Liner
Window Tint
PRG UCA 3" Front lift
33" Tires on stock rims
Front and rear aftermarket bumpers
Further mod suggestions welcomed!
Kindly,
Dave
Same stuff work on all 08+ so your fine, depending on wht size tires you have on now, you might all ready be running skinny 33's. A 275/70/18 which is a stock tire on some models is a 33" tire. They will look fine with a 3" lift, that is what I am running, I would suggest some performance mods to add some power - Airaid CAI, Bullydog GT tuner, and either a muffler swap or a catback, Borla seems to be the most popular lately. You can usually find guys selling usd Bullydogs for about $225-250, most that are selling are moving on to Uprv as a tuner.
Reactions: overture2112
Well I put a rough country 2" leveling kit on this weekend. Install was a bit tougher than I anticipated. But it rides well with just a touch sway. Really give a noticeable change in look for the better. Approx hours for install= 7 ( because it's an '06 so I fought every bolt and because the instruction left out the part about needing to switch side with the struts after spacers are on) approx cost= $110.
I admit I haven't read all of this thread, but I think I have what knowledge I need...
Purchase: Black Billet Coil Block Spacer
I plan on taking this to a local shop and have them install it when I get new tires and have them align at the same time. Should that work without any noises or damage? Do I need any additional parts? Thanks!
I am told by PRG if you go to high on the spacer the UCA's will hit the coil bucket. Some people will grind them down and this does not interest me, doing any cutting or grinding on my new truck :). That is why I am considering his package with the UCA's. It is kind of pricey IMO, but this it is a better solution for my needs in the long run.
If Im looking at that right it is a 1.5" lift spacer which iirc that will be 3" of lift in the front... if that is the case you will need new uca most definitely... if that is a 1.5" level spacer it shoud be .8" thick which you would not need uca with that...
Reactions: jbowles
