I got a 2006 Titan SE and at 21k miles, my Titan died. Before, it used to have excellent throttle response, it would downshift with the quickness and the RPMs would pick up much faster. Any ideas why this happened??? Thanks
ArmyAviation said:no one has posted yet? what do you mean "died"? theres alot of things that can cause your truck to be sluggish, bad fuel, dirty throttlebody, clogged air filter, dirty/clogged fuel injectors
why use 91 octane? truck runs on fine on 87. I use the B&G fuel treatment every 20k went I had my 02 durango, I havent put that many miles on this truck yet to use it. Loss of power is caused by bad injectors (dirty or clogged). Check you plugs or just 1 of them and see what it looks like.pedalhappy1053 said:Before 21k miles, my truck had tons of power. When i used to floor it, it would pick up 4500 RPM and now it jus picks up to about 3000. I clean my filter every oil change (3k miles), i use 91 octane. I dont think the injectors are dirty.
If you haven't already, post this over at CT as well and see what some other guys think.pedalhappy1053 said:I got a 2006 Titan SE and at 21k miles, my Titan died. Before, it used to have excellent throttle response, it would downshift with the quickness and the RPMs would pick up much faster. Any ideas why this happened??? Thanks
I had that happen to my old 94 nissan altima after going through a big puddle I found out it sucked water into the intake and it mad it go into some strange mode. It was ok the next dayboya544 said:A few months ago I experienced a power loss. It was raining and as I drove over some RR tracks the tires spun as it shifted into 3rd. After that the truck was stuck in 3rd. When I came to the next light the truck took off like I was going up a steep hill.It was really sluggish and when I gave it gas it would not go over 3k rpm. It acted like it does when the rev limiter kicks in. At the next light I noticed while taking off it did not shift.It was starting off in 3rd gear and stayed in 3rd.I could not even manually shift.I drove like this for about 10 mi. No lights came on when this happened.I then shut off the truck and restarted it and drives fine.It has been a little over 1500mi. and the problem never reoccurred. My buddy who owns a Dodge told me his did that when his trans overheated while towing his boat, but his cel light came on.The dealer told him when his trans overheated the truck went into limp mode. They had to reset his ecu. So i'm wondering what happened to mine? I was not towing or hauling anything.
4wheelpeel said:Pedalhappy any word on what the problem is or was?
Yeah - sounds like when you got wheel spin going over the tracks you could've given the tranny a little bump into some sort of safe mode. Does it still do this? Have you tried the ECU reset?boya544 said:A few months ago I experienced a power loss. It was raining and as I drove over some RR tracks the tires spun as it shifted into 3rd. After that the truck was stuck in 3rd. When I came to the next light the truck took off like I was going up a steep hill.It was really sluggish and when I gave it gas it would not go over 3k rpm. It acted like it does when the rev limiter kicks in. At the next light I noticed while taking off it did not shift.It was starting off in 3rd gear and stayed in 3rd.I could not even manually shift.I drove like this for about 10 mi. No lights came on when this happened.I then shut off the truck and restarted it and drives fine.It has been a little over 1500mi. and the problem never reoccurred. My buddy who owns a Dodge told me his did that when his trans overheated while towing his boat, but his cel light came on.The dealer told him when his trans overheated the truck went into limp mode. They had to reset his ecu. So i'm wondering what happened to mine? I was not towing or hauling anything.
