Major improvement after disconnecting “smart” alternator charging
5 reading
20K views 73 replies 31 participants last post by  maxmind
I disconnected the smart alternator charging cable from the negative battery terminal and it made a huge difference. It cleared up delays in throttle response and shifting immediately and the truck is just so much better to drive now.
After thinking about it a bit, it makes sense. Not only is this system shredding batteries (because lots of charge and discharge cycles are bad for lead acid batteries), but the overall electrical system is being underpowered much of the time when the alternator is switched off which is causing issues for the ECU/TCU programming and various electro-mechanical systems. It also explains the intermittent nature of these issues since sometimes the alternator is running and sometimes it isn’t.
I recommend everyone at least try disconnecting the smart alternator connector and seeing if it makes a difference. It takes maybe 30 seconds and is super easy to reverse if you don’t see an improvement.
#2 ·
Seems like a good idea.
I am already annoyed by the smart charging, I can clearly see, on the voltmeter screen, when the truck is or isn't charging. It's a nearly 2v difference.
I never correlated it to drivetrain performance (my Gen 1 didn't behave as oddly as my Gen 2, despite also having the same system) but since I rely on my truck battery for camping, I didn't like that it wasn't always charging, like older setups did. I feel like sometimes maybe the battery hasn't been charged 100%
#4 · (Edited)
Interesting. Everything I’ve seen on here and the Titan Facebook groups seems to indicate the smart charging system doesn’t play nicely with AGM batteries and needs to be disconnected. Not saying you’re wrong, I’m not familiar with the nuances between lead acid and AGM batteries, just that there seems to be conflicting information about this.
#5 ·
An AGM charge profile is different from FLA charge profile. An FLA charge profile used on an AGM battery will result in premature decline of the battery. I had that happen to my Odyssey batteries in my UTV. I was able to recondition them fortunately. The Odyssey in my Titan didn't fare so well and had to be replaced just before the 5 year (at that time) warranty expired.
I now use a smart charger with an AGM charge profile to maintain my AGM batteries.
#6 ·
As HRTKD states, they are different charge profiles. Will it work yes. But with a traditional charger on an AGM battery it will only charge to approximately 80%.
Ive started numerous times every time this topic comes up, that it’s a bad idea.
Search does AGM battery require a smart charger, answer is yes everywhere.
#7 ·
so, reading all the replies, your options are:
a: unplug battery sense wire and truck reads normal voltage and everything on the truck possibly works properly, though you may have to buy a battery more often if you happen to have a specific type of battery in your truck.
b: leave battery sense wire plugged in and deal with odd voltage fluctuations and maybe have weird electrical gremlins but your battery may last a little longer if you have that specific battery.
i unplugged mine and never trouble with the battery or weird electrical gremlins.
though, just to be equal, there are probably tons of people who have not unplugged their sense wire and also have no problems
Reactions: Roush and TurboDA6
#8 ·
My boat runs 2 batteries, an Optima Marine AGM for the "house" battery, and an Interstate FLA Marine starting battery.
There is no adaptive charging, just a Blue Seas ACR to isolate the house battery during starting and run. When the alternator is charging, both batteries are being charged simultaneously. The ACR doesn't care about battery type.
Both batteries lasted 15 years, they both died in the same boating season.
I've also used AGM red top Optimas in my vehicles in the past. No vehicle had smart charging back then. And those USA made Optima red tops earned a reputation for being the best choice for an upgraded vehicle battery.
Notice I say USA made, because they no longer make their batteries in USA, and the quality has gone way down since.
I don't agree that AGM requires the smart charging. Charge profiles may be different, but the basic LA characteristics are similar enough that they are interchangeable irregardless of charging type. Remember, all vehicles had regular alternator charging when Optima gained its reputation as a great battery.
#10 ·
I believe my original battery said enhanced flooded battery.
This is my second Titan with an AGM in it and no issues and wire still plugged in.
Clint
Reactions: TurboDA6
#11 ·
AGM is just a variant of the LA batteries. They are specifically made for use in any vehicle. And have been for decades.
Finding deeper tech information on new Nissan vehicles is damn near impossible, I am curious how some of y'all get your information, or.... disinformation, for that matter
#17 ·
So what is the intended purpose of the "smart" alternator? Is it simply a fuel savings mechanism? If so, does that mean the alternator creates more drag on the engine when it is actively charging as compared to when it is not charging? So disconnecting the smart alternator cable at battery will effectively force the the alternator to charge 100% of the time the engine is running?
#18 ·
I have more experience with LiFePO4 batteries than FLA/AGM. With a LiFePO4 battery, while it can be charged up to 14.6 volts, we typically don't. 14.4 volts is usually enough on the bulk charge and then we fall back to a float charge of 13.6 volts at reduced amps.
I would think that continually charging an FLA battery at 14.5 volts would eventually cook it but the amps to get reduced by the alternator, smart or not. I do agree with you that the alternator has no idea what type of battery is in the truck. Even the smart chargers like the CTEK MUS 4.3 that I use don't know what battery is there. I have to manually pick the right battery.
The newer model Ford Super Duty has a setting in the truck's software for an AGM battery. One of these days I'll get around to changing that setting on my F-350.
#19 ·
You’re correct that a floating voltage of 14.5V on a fully charged SLA would overcharge and damage the battery if left long enough, but a vehicle battery is under load while the vehicle is running, so for the alternator to maintain a (nearly) full charge on the battery, it has to run at the power absorption voltage, ~14.5V. On a charger (battery not under load), once the battery is fully charged the voltage should drop to the floating charge level which no longer charges the battery but keeps it from losing charge (if the charger just stopped applying voltage altogether, the battery would slowly drain back through the charger from parasitic draw until physically disconnected).
#27 ·
I couldn't get the plug disconnected on my wife's 2013 Infiniti EX37 so I cut the wire with the help of an ASE certified Nissan tech on nicoclub. One time the alternator quit charging and I was going to take it to the dealer to repair but I put a charger set on 25 amps on the battery and I also started the engine trying to figure out why the brake light was also on as well as the battery light and when I disconnected the charger and left to go to the dealer the alternator was charging again. So, I assumed the computer had a brain fart and the charger woke it up. Anyhow, the sensor is disconnected now.
#29 ·
So should I disconnect? I don’t know of any problems I’m having and a cheap meter I have plugged into the DC outlet always shows 14v -15v. But I do want my battery at maximum charge at all times givin that I charge batteries for tools off of it regularly. Also I got a little lost reading. Are you guys also saying that a car battery standing alone fully charged would be 14.4-14.6v?
#35 ·
Dang, unicorn battery there
  • Haha
Reactions: Roush
#39 ·
i have been seeing lots of new vehicles (on the other forums i am part of) have smart charge alternators now. and the common thing i see is people who use an external plug in charger, every once in a while, on the battery get 4+ years out of the batteries.
  • Wow
Reactions: Roush
