Power cord thru firewall
1.8K views 11 replies 6 participants last post by  smoketitan
Where did you guys get your power wire thru the firewall? do you have pics? is it a pain in the a$$? How many feet did you need to reach behind the back seat? Thanks for the help...
#4 ·
This is my problem also I can't decide wether or not 4ga will be enough...Technicaly it is not big enough for my amps, but neither one runs at full power.
I'm supposed to have 1 4ga and 1 6ga but the 6ga amp is just for the front components. Maybe after I hit over 5000 miles I will feel less bad about drilling a 1 inch hole into my Babys firewall?
#6 ·
You'll never see the hole, and if you decide to sell the truck, a piece of aluminum flashing and some sound mat will easily cover it.
#7 ·
Sammy....you might have already done this but could you take some pics of the firewall hole (from the cab and the engine bay)? How did you get the drill in there? What side did you go through? Would it be easier to go through the inside of the cab if I removed the glovebox and drilled from there? I took a quick look and I just want to be sure I am drilling in the same place as others have already done. I want to do it right the first time.
#8 ·
I'll try to get a picture today. I drilled from the cab forward, using a smaller bit for a pilot hole. I already had my glove box removed, so I can't really tell you if it's in the way or not. It would probably be impossible to go from the engine side, because there isn't much room to work in.
#11 · (Edited)
smoketitan said:
wow how did you get that pic--lol
mine went through the lower tip of the N on the firewall I used a small carbide bit to pilot the hole then used a unibit with a 1" step to drill the hole
youll need at least a 18v drill or corder version with some power
Just pulled back the carpet and foam and snapped it, not hard. I never saw the "N" you guys were refering to. I just tried to take measurements based off of the A/C drain on both sides. I used a small bit to ensure it was properly aligned. My first hole came out too close to the drain on the engine side, the one that runs out towards the side of the truck. I covered that small hole with the bquiet you see there, then adjusted from there. I couldn't find a 1" unibit, so I had to use a hole saw. That sheet metal is pretty thin, so it wasn't too difficult, although I did bend my hole saw's center bit (cheap.)
