Power Outlet??
2.2K views 5 replies 5 participants last post by  bestatchess
Hey guys new here..went on a road trip last week going snowboarding and had the kids playstations hooked up to my power outlet through the converter and we blew the power outlet fuse and I cant find it anywhere?? Any help?? Fusible links are ok..no broken fuses inside passenger side??
#2 ·
Check under the hood, passenger side towards the firewall. Can't remember which box its in but I'm betting a blown fuse in there.
#5 ·
CHECKED every fuse on the inside passenger fuse box, nothing blown??
#6 ·
1. try swapping fuses between power socket circuits in the passenger dash fuse panel - sometimes fuse it bad but looks ok.
2. test the socket with a meter or known good device (works in other socket - maybe the inverter has a fuse that failed)
3. visually inspect the contacts in the socket, maybe they are damaged, not making contact.
4. I assume you know some of the sockets are on only w/ ignition.
