i have an excellent fix for those of you with the annoying power seat. now this will only be helpful if you are the only one who drives your truck (or at least most of the time) or if you dont have the exit/entry feature (or you dont care if it works)
1. get in your truck and adjust your seat to the position desired
2. carefully get out of the vehicle without touching the switches or letting the cusion push the switches
3. look under seat, there are 2 plugs that are attached to the bottom of the seat, a smaller one and a bigger one.. (there is a 3rd humungous plug, dont touch that one) the plugs run front to back and are in center front to back and on left and right of center... unplug those plugs (may be a little tricky if youre not used to these plugs) volia.. problem fixed
... oh you could wire a swith also but i was too lazy... lol
