It's also parked on an incline which is compressing the rear a bit. I'd wait to see a picture on flat and level.GETSOMZ28 said:It looks like the front is higher than the rear?!?
A coil spacer with factory shock?? :huh: That's kind of crappy...I guest it will save you some money though. I think I am going to hold out for RCD to come out with one. Hopefully they will have a 4-6" by next year using some BilsteinsKC8 said:More information on the Procomp suspension lift. They wrote...
A coil spacer will be used with the factory strut assembly and the rear is lifted with a 3" tall block." [/I]
By coil spacer they mean the mounting point for the whole strut assembly is moved downward, the same thing CST and Rancho do. Otherwise a longer coilover or strut (read $$$) would be required. This set up maintains the factory ride.SarkaZm said:A coil spacer with factory shock?? :huh: That's kind of crappy...I guest it will save you some money though. I think I am going to hold out for RCD to come out with one. Hopefully they will have a 4-6" buy next year using some BilsteinsI'm not too impressed with the current offerings. The CST looks good, but 8" is too much for my taste.
Thanks for the info. Not that the stock suspension is bad, but if I am going to lift my truck I would hope that it would give me a few more inches of travel as well. I have never done a lift before (my first truck), but I am assuming if you use the stock struts/coilovers then the travel would be the same? The Titan stock suspension seems to be lacking in this area.sammy sandbag said:By coil spacer they mean the mounting point for the whole strut assembly is moved downward, the same thing CST and Rancho do. Otherwise a longer coilover or strut (read $$$) would be required. This set up maintains the factory ride.
Well it's limited also by the actual design of the entire front suspension. Most long travel kits utilize longer A-arms, which (think geometrics) gives more travel. The thing is with an IFS and longer A-arms, you'll also need longer steering links, and more importantly longer CV shafts. This is why you don't see many long travel 4WD kits for IFS trucks, it's more common on 2WD. Without making modifications (replacing) the A-arms, you'll still be limited by the degree to which you can cycle the suspension without binding the CV joints. These operate best when nearly on the same plane as one another, too much angle and bad things happen. You may have also noticed and integrated bump stop in the lower A-arm, another thing limiting travel (in a good way of course.)SarkaZm said:Thanks for the info. Not that the stock suspension is bad, but if I am going to lift my truck I would hope that it would give me a few more inches of travel as well. I have never done a lift before (my first truck), but I am assuming if you use the stock struts/coilovers then the travel would be the same? The Titan stock suspension seems to be lacking in this area.
So I guess you are saying that if I want to increase the travel...it's gonna cost me?sammy sandbag said:Well it's limited also by the actual design of the entire front suspension. Most long travel kits utilize longer A-arms, which (think geometrics) gives more travel. The thing is with an IFS and longer A-arms, you'll also need longer steering links, and more importantly longer CV shafts. This is why you don't see many long travel 4WD kits for IFS trucks, it's more common on 2WD. Without making modifications (replacing) the A-arms, you'll still be limited by the degree to which you can cycle the suspension without binding the CV joints. These operate best when nearly on the same plane as one another, too much angle and bad things happen. You may have also noticed and integrated bump stop in the lower A-arm, another thing limiting travel (in a good way of course.)
Wow, thanks for the good info Prerunner! What you're working on sounds like what I am looking for. My main concern IS an improved ride (on road) and better bottoming resistance. This truck just bottms out too easy...so what your saying makes sense. It's good to hear that somone such as yourself is working on these type of things. Thanks again!PrerunnerGreg said:To increase travel would be nice. As it stands right now, the droop travel limit is the upper a-arm hitting the lip of the coil bucket, followed shortly by the tierods binding. The compression travel is limited by the lower bumpstop. Stock, the truck has a fair amount of travel (about 8-9 inches). The problem is crappy shocks and being either under sprung (regular suspension) or oversprung (off-road package). There is over 200 lbs/inch difference in the different springs (<550 vs. >750) , crazy! If a longer shock were used and the upper a-arm modified you could probably get 10-11 inches of travel, that is a really decent amount. Im working on using a fox 2.0 coil-over to gain a couple inches of travel and, with custom valving, a much better ride, all while using the stock spring. The factory shocks are just too small to achieve any decent bottoming resistance (the ranchos are just as bad). Im also looking at using some King 2.5" coil-overs to really improve the ride. Both these systems will give ajustable ride height, you could even use them as lowering struts too. As it stands CST has a long-travel kit, but it is spendy. It is easy enough to build longer a-arms, so that will be in the near future too, as well as a raised spindal. So stay tuned.
When I spoke with ProComp, they said more than likely it will work with both 2 and 4wd, since the front ends are identical, I guess we'll find out. I personally don't have experience with Pro Comp, but my old roomate has a 6" Pro Comp lift on his Chevy 1500 and it is very nice quality.SarkaZm said:Does anyone know if they have a 2wd version? Everything sounds sweet, but is anyone here familiar with Pro Comp's quality? Will it be as nice as it sound? Regardless, it's good to see more products for our wonderful trucks!!
