Hi, New here and just bought a 2011 Nissan Titan SV 2WD. It has really rough idle. Previous owner states changed Coil packs and plugs and still is running rough. I have really bad hearing but kind of sounds like air is leaking under the hood but do not see any hoses that appear broken. Any help would be appreciated. Also, Getting codes - P0300 (Random/Multiple misfires), P1148 (Closed loop fault detected bank 1), P0031 (H02S Heater control circuit low Bank 1 Sensor 1), P2122 (Throttle/ pedal position sensor/switch d circuit low). Thanks.
All System Diagnostic Report
The Report is created by THINKCAR
Vehicle Information
Make:NISSAN
Model:Titan
Year:2011
Test Time:01/04/2024 10:15:53
Read DataStream:
Name Value Unit
A/F ADJ-B1 -0.050
A/F ADJ-B2 -0.044
A/F Alpha-B1 75 %
A/F Alpha-B2 100 %
A/F S1 HTR(B1) 48.80 %
A/F S1 HTR(B2) 36.80 %
A/F SEN1 (B1) 2.12 V
A/F SEN1 (B2) 2.19 V
AC Press SEN 0.67 V
Accel SEN 1 0.74 V
Accel SEN 2 0.77 V
AIR Cond RLY OFF
AIR Cond SIG OFF
ALT Duty 0.00 %
ALT Duty SIG OFF
AT OD Cancel OFF
AT OD Monitor OFF
B/Fuel Schdl 5.47 Ms
BAT CUR SEN 2545 mV
Battery Voltage 14.16 V
Brake Operation Judgment OFF
Brake SW1 On
Brake SW2 OFF
Brake Switch OFF
CAL/LD Value 41 %
Cancel SW OFF
Clsd THL POS On
Coolant Temp/S 152.6 degree F
Cruise Lamp OFF
Engine Speed 812 rpm
Ethanol M/R 40.00 %
Evap SYS Pres 4.18 V
FPCM Hi
Fpcm DR Volt 0.16 V
Fuel Level SE 2.4 V
Fuel Pump Relay On
Fuel Temp SEN 42.8 degree F
Heater FAN SW On
HO2 S2 DIAG2(B1) Not Completed
HO2 S2 DIAG2(B2) Completed
HO2S2 (B1) 0.84 V
HO2S2 (B2) 0.74 V
HO2S2 HTR (B1) On
HO2S2 HTR (B2) On
HO2S2 Mntr(B1) RICH
HO2S2 Mntr(B2) RICH
I/P Pully SPD 700 rpm
IDL A/V Learn Completed
IGN Timing 12 Btdc
Ignition Switch On
INJ Pulse-B1 2.55 Msec
INJ Pulse-B2 3.14 Msec
INT/V SOL(B1) 0 %
INT/V SOL(B2) 0 %
INT/V TIM(B1) 0 Degree CA
INT/V TIM(B2) -0 Degree CA
Intake Temperature Sensor 55.4 degree F
LO Speed CUT Non
Load Signal OFF
Vehicle Information
Make:NISSAN
Model:Titan
Year:2011
Read DataStream:
Name Value Unit
A/F ADJ-B1 -0.050
A/F ADJ-B2 -0.044
A/F Alpha-B1 75 %
A/F Alpha-B2 100 %
AC Press SEN 0.67 V
Accel SEN 1 0.74 V
Accel SEN 2 0.77 V
AIR Cond RLY OFF
AIR Cond SIG OFF
ALT Duty 0.00 %
ALT Duty SIG OFF
AT OD Cancel OFF
AT OD Monitor OFF
BAT CUR SEN 2545 mV
Brake SW1 On
Brake SW2 OFF
Brake Switch OFF
CAL/LD Value 41 %
Cancel SW OFF
Clsd THL POS On
Cruise Lamp OFF
Ethanol M/R 40.00 %
FPCM Hi
Fpcm DR Volt 0.16 V
Fuel Level SE 2.4 V
Fuel Pump Relay On
Heater FAN SW On
HO2S2 (B1) 0.84 V
HO2S2 (B2) 0.74 V
HO2S2 HTR (B1) On
HO2S2 HTR (B2) On
HO2S2 Mntr(B1) RICH
HO2S2 Mntr(B2) RICH
IGN Timing 12 Btdc
Ignition Switch On
INT/V SOL(B1) 0 %
INT/V SOL(B2) 0 %
LO Speed CUT Non
Load Signal OFF
