Just thought I'd share my .02 about my experience with re-gearing our beloved trucks. Or anything else for that matter. I personally will NEVER put another spaced ring gear in a vehicle of mine. After almost 20k miles the ring gear bolts had worked loose to the point one of them finally dislodged and hung up in the housing. Holy hell that was a sickening noise. Luckily it happened in my neighborhood and not at 65 mph on the freeway 2 minutes before.
I'm not here to bash any one particular brand. Just be aware if you are thinking about a re-gear, ask if the gear is made for the Titan or if it's a spaced out Jeep JK gear. I had my reservations about the spacer to begin with, and should have gone with my gut. Now, three weeks, new Ring & pinion, carrier, paying a welder to fix the case, new install kit, etc. later, it's back on the ground and I'm breaking in gears again. Lessons learned.
