Roof mounted led bar question
20K views 41 replies 18 participants last post by  Titan67
Do the mounts require drilling holes into the roof? Really want a light bar but kinda nervous about drilling holes in the roof.
Thanks
#3 ·
along with the wires to power the lightbar...
#6 ·
If you aren't a do it your selfer, it isn't. To get it done right, costs a little bit.
#5 ·
Took me a while to build up the balls to drill holes in my roof, but so glad I did lol. My truck isn't brand new though.
#7 ·
I know a guy has the same concerns so he was looking into rare earth magnets. Regardless you will have to drill for the power wires.
#8 ·
You can find somebody to make a fabricate a mount to were it will mount in the door sill and run the wire behind the weather stripping
#11 ·
/\ this and it seems like I saw some kind of brackets that lock into the two drain channels for the mounts.
#9 ·
Just a thought.... even if you find a way to mount it there without drilling, you'll someday have a different paint tone under where it was because that spot won't be faded from the sun.
#12 ·
Just a though here, but the rain gutters where my mounts sit are filled about 1/4" thick with silicone and painted from the factory so in theory if you ever wanted to go back to stock you could seal up the holes then silicone back over them and paint them.
#17 ·
I got mine from SoCal supertrucks, but rough country makes them for a whole lot cheaper now and appear to good quality. Had they come out with their curved bar mount 3 weeks sooner I'd have got it instead lol. Solcal's run $200 I believe (got mine on sale for the 4th) and rough country's are I think $60? Only thing I like about mine is that the mounting bolt for the bar is recessed so you can't get a pair of pliers on it to steal it but honestly not worth the extra price unless the RC's were far inferior which I don't think they are.
Reactions: BrandonVK56
#22 ·
FYI, you don't necessarily need to drill for the wires as well. I mounted a roof basket on my titan and then after the fact wanted to install a light bar. I actually just ran the wiring for the light bar right down the a-pillar and tucked it under the windshield surround. At the bottom it went under the cowl and into the engine bay to the relay. Everything looks like it was never touched. If you are drilling the mounts and have the light bar at the same time then I guess going ahead and drilling for the wiring isn't a big deal. It's like they always say, "what's one more hole?"
#24 ·
I have the rough country mounts with a straight bar. They are great for the price but like you've discussed you have to drill in the roof and I'm kind of over it and wanting to go another route but I have holes in my roof and I'm trying to find a way to get it off and get the holes filled. Not to thread jack but if y'all have any ideas send them my way.
#25 ·
Take the bolts out and install some set screws with lock tight and silicon. Get them short enough so they will screw down flush with the roof. Just an idea….
#27 ·
Drill the holes and get over it lol jk well worth it. I have a post on here but I thought I'd share here too.
50" Cree Curved Led Light bar
Rough country mounts (nice quality too)
Remote wireless (no interior switch) harness
#29 ·
theres a guy i follow on instagram who has Clip on mounts that mount the same way thule roof racks mount, but hes one of those D-bags that if he has something, hes the only one with it and doesnt want anyone else knowing where he got them... so... keep in mind, theyre out there somewhere, i just dont know what to search for
#32 ·
#33 ·
Mine is a Genssii brand 54" and it felt a lot higher quality than I expected it to. I did some bartering of other parts for the light bar so long story short I've only got about $45 into it not including the $30 wiring harness/switch. For that price, I figure if it snaps in half after 6 months it was worth the money. So far it is working great and have seen no signs of issues cosmetically or otherwise. Granted, I have only had it on the truck for a few weeks but the past week or so has been ~20 degrees out on average so the weather hasn't seemed to affect it.
#34 ·
Do you pics if the bar? Is the bar itself 54" or with the mounts 54"? Somebody here told me it would not work
#35 ·
I believe it's about 54 inches from the very outside edge of the mount platform to the other edge. True bar width is probably about 52 inches. If you were mounting directly to the roof of the titan than you are probably right. The mounting feet would probably land somewhere on the very edge on the roof. That wouldn't look too good. I have a roof basket on my titan so the light bar is just mounted to the front of that. I'll try to take some better pics of how everything is mounted today.
#38 ·
If you get the rough country mounts make sure you get a bar that is exactly 50 inches from end to end or it will not fit I had a 52 and sold it to get a 50 that fit.
#41 ·
Do you have any pics of your setup would really like to see it
