radiokid said:
Sorry if this has been addressed before but after searching for information on the subject I haven't been able to find much.
I have RF sound system and recently noticed a pop sound coming on particularly bass heavy like kick drum passages that has the sub making non musical sounds. I suspect I have reached the limits of the system perhaps frequency wise as turning up the volume( only at 20 anyway) doesn't increase the pop at all, only certain frequencies do. Is there a fix for this??
Yes, hopefully. As the problem has been explained to me, the speakers, sub, and the amp in the RF are all poor. Particularly, the amp is underpowered, which will cause the speakers to distort when pushed to higher volumes. Replacement of the speakers alone will not solve this problem, as the RF amp will cause even high quality speakers to distort, potentially ruining the new speakers in the process.
My fix (in progress) involves two amps, two sets of component speakers, one sub, an LOC, sound deadener mat, and a bunch of wires. There are some threads like "custom sub box project" and "installing aftermarket radio" that have alot of info. I don't know much about the subject, but I have a pretty high confidence level about this project after getting all of that info. I believe that some people may have installed an amp & sub while leaving the stock speakers. I bought an adapter/harness that is supposed to plug into the back of OEM Nissan head units that I am hoping to use to connect the head unit to the LOC, and then the LOC provides the input signals to the amps.
I don't know if every RF has this problem, but my rear door speakers make very "non-musical sounds" if you turn the fader to the rear. Also, if I listen closely to the dash tweets at higher volumes, they are also making "non-musical" sounds.
