Thr first recall for 2020 - 2022
5.8K views 22 replies 12 participants last post by  bluovalguy
#7 ·
I think Nissan may have over complicated the park pawl on the 9 speed transmission. The 7 speed park pawl was pretty straight forward cable operated park lock. Not so much for the 9 speed. The 9 speed is actuated by an electrical signal coupled with hydraulic pressure from an electric pump located in the transmission valve body. When the truck is parked the pump operates an actuator that pushes on a rod that in turn pushes the park pawl into the park ring gear. Park is then sensed by a magnetic position sensor read by the TCM. Good grief. Makes me wonder what exactly they will do for the fix.
#13 ·
Transmissions are designed for putting power from the engine to the wheels. Brakes are made for slowing/stopping/holding a vehicle in place. This is why I have never relied on my transmission to hold my vehicle in place. Therefore, I need to do nothing different than I already do here.
Well spoiler alert, it's based on a Mercedes design, so we got a tad of that "German Engineering" going on here.
#8 ·
My friend has a towing company and has made more than a few calls to help people who’s vehicle is stuck in park due to the weight of the vehicle jamming it in park.
You all do as you wish but the parking brake is there to hold the car not the pawl.
Clint
#9 ·
Clint
Would specific cars have the common issue? I have had cars/trucks and I never have experienced the lock up. My old subaru with cvt even didn't have that issue.
#11 ·
If you don’t use it and one day try it the cables are known to seize inside the casing and get stuck on then you need a flat bed and new cables. Using them all the time stops that from occurring.
Again, I do me and you do you, stay safe out there.
Clint
#15 ·
I had a good reason to use the parking brake this weekend in Austin, but I keep forgetting since it's an auto. Parking on the hills whn I would get in and try to shift to reverse, you could hear and feel terrible clank from the transmission trying to shift. Made me cringe each time and I would comment to my wife that I need to use the e-brake.
I use it every time in the ranger, of course it's a stick
Reactions: Clint
#16 ·
I doubt my parking brake would even hold the truck, every time I apply it when hooking up our trailer the damn truck still moves forward a few inches until the transmission catches it....it's aggravating trying to hook up to our trailer on an incline, I have to intentionally overshoot the coupler by 2-3" and then set the parking brake and wait for it to roll forward..
#18 ·
Using the parking brake definitely eliminates any possibility of torque lock in the transmission. I usually set my parking brake then shift to neutral and let the truck come to a rest against the brake. Once it's settled I then shift to park and turn off. Helps eliminate any stress on the pawl and makes for easy and quiet shifts from park when leaving.
#20 ·
I saw this article a few days ago and figured it would be disseminated and dissected every which way in here. :ROFLMAO: I use my parking brake all the time, and I actually don't like putting my car in gear when parked (I know a lot of people say that's not a good practice, but I've seen too many people start a car in an enclosed space and watch the car lurch forward manual transmission --- video added for your entertainment... ). I can't remember where I saw it, but I remember a scene where a guy loaned someone their car. The person left the car in gear and didn't apply the parking brake. The owner of the car screamed at the other person, "The transmission is NOT a kickstand!" For whatever reason, that line stuck with me. One day I used it on my BiL (he has this annoying habit of breaking other peoples' things) when I let him borrow my truck and got a good laugh out of him. I definitely do hate letting the car's weight sit up against the transmission. I figure replacing brake pads is cheaper than replacing a transmission.
#21 ·
Wow /\
Brand new with sticker on the windows still
#22 ·
The last few seconds are what had me rolling (aside from it being a Mustang :ROFLMAO: ) "Don't worry we'll get you a new bike" and the "Did you get this all on film?" "Shut up!" :LOL:
With splitting time between two very different vehicles, I always feel like I'm going to be in the manual thinking I'm in the 1-speed auto and forget to shift gears, which is why I don't set the gear shifter when parking (but will definitely apply the parking brake). Interestingly enough, I've found myself on a couple of occasions reaching for the column shifter that was on the Titan on my other vehicles.
One thought I had on this issue (which means it can probably happen on other vehicles) is with cars set to automatically disengage the parking brake when the car is in gear and someone applies the gas as a way to avoid people driving with their parking brake on, what if the vehicles are disengaging the parking brake as they were designed to do thinking that someone is behind the wheel? I guess maybe I'll have to reconsider putting my car in gear after I park. Gotta love it when something isn't engineered with all conditions considered. :cautious:
