Tips for installing door hinge
21K views 13 replies 8 participants last post by  spta97
My driver side door needs new hinges so I bought the upper and lower. Does anyone have any pointers or tips for installation? Thanks
#3 ·
Not sure but you should be able to just replace the bushings instead of the whole hinge assembly.
#11 ·
I replaced both hinges on my drivers door this weekend.
The correct way to do it is to remove the fender. There are 7 bolts and 5 screws involved to get the fender off.
Remove all screws holding the plastic fender liner in
Remove the wiper arm by removing plug cap and nut then wiggle
Remove wiper cowl covering or at least pry up
Remove hood shock and support hood to hold open.
Remove all bolts holding fender on. 3 on the top along with the strut pin.
Remove the bolt behind the from fender
Remove the 2 bots located in the door opening and the final bolt down by the mud flap
Remove and replace both hinges and adjust so the door does not hit the strike bar
Replace the fender and be sure that it does not come in contact with the door when being open and closed. Adjust gaps as needed.
Be sure to replace both hinges, they are cheap. I didn't get any pictures but its an easy process. Took about an hour start to finish
