Hi all,
We got a travel trailer that is 5,400 dry but we'll probably load another 600lbs or so for an even 6,000lbs. We're taking it to a camping trip up at Big Bear Lake this weekend and I'd like some advice on towing in the mountains. I towed it once to an elevation of 4,600' and only noticed the tranny go almost redline once on a gradual but sustained climb.
I've read to keep in in 4th gear (not the od 4th). We have the Prodigy brake controller, and WD hitch. Everything else is stock. I have noticed that when I get out of the truck I hear slight creaking from the rear tires. It's as if the shocks are slowly coming back up or something. Everything on the 05' SE is stock.
I'll fill the tires to the max of 35lbs.
I'd like some advice on towing with my rig as well as towing in the mountains.
thanks,
Nate
thanks,
Nate
