21 - 26 of 26 Posts
Whatever brand or whoever installs it make sure the install is neat and all the wires under the dash are protected with a wire loom or some anti-abrasion tape. The metal under the dash is very sharp almost serrated from the stamping process. And that goes for all you guys that had them installed do yourself a favor and drop the driverside under dash and take a peek at the install, If the wires are running through the holes of the metal stamping, wire loom it or tape it up good. The reason I say this, My truck came with a viper alarm and auto start and the install was horrific. I found out the hard way. Driving home from work one morning the power locks locked on there own. I thought it was a fluke, a couple of miles down the road the locks started going ape sh!t. Then I smelt burning rubber, Then I saw flaming rubber fall onto my sneaker. I quick pulled over and ripped the battery cable off, took the dash apart and saw the carnage. I had to put the truck back to stock on the side of the road just so I could get it started due to the antitheft. Wasn't fun. The viper unit was pretty cool, I could start the truck from about 400 ft. through a concrete wall, the viper remote gave a confirmation beep when it started.
Does Nissan make a factory one for the Titan? My dealer says they do not offer a factory one. I was hoping Nissan might make one that does not require splicing into the wires.
Just talked to my local dealership-
They have a 'Performance center' that does the installs- $299 out the door- includes parts, labor and bypass module. It's a Crimestopper unit- with lock/ unlock/ remote start.
AND its has a lifetime warranty on the remote start AND does not void the factory warranties in any way...
Sounds like a pretty good deal?
JERRYMAC said:
Jim: I've read where the Viper system works up to 1 mile. The system replies back to you when the vehicle starts. Have you experienced such starting distances with your system or heard of such? THANKS much.
I had the Viper Valet installed on mine at Best Buy for around $300 out the door. My cube is about 2 football fields away from my truck. I can hit the button at my cube in the office and the truck will start. The range is incredible.
21 - 26 of 26 Posts
