I have a CC XE(which doesn't have nav). Does anyone know if the factory Nav is plug N play.
ANY help is greatly appreciated. Thanks
That sucks bad......Thanks alot man!!!!!!!!rrumaner said:Plug and Play is only good if you have the connections, sensors, DVD player and everything else that is needed to make the Navigation work. Sorry but AFAIK you would be better off buying a Garmin or TomTom at this point.
I see what alot of the guys did. That is alot custom work that I can't do.baseballfanz said:It's not prewired, even the LE without OEM nav is not prewired. Parts alone would run you over $5K not including labors to get it install.
Best to go after market IMO. There are a few peoples who have intergrated an after market nav screen into the OEM nav bezel for a factory look.
