21 - 25 of 25 Posts
All these guys are giving you great advice, the only thing I can add is stay away from the welded steel leveling kits, quite a few guys have issues with those (stripping threads, bending and stuff) pretty much any solid billet aluminum kit on ebay with a lifetime warranty on Ebay will work just fine with no issues.
Reactions: Quartz
No problems with the welded steel leveling kits
I have an alldayfab leveling kit which is the welded steel style
In my accident I hit a sewer and bent the rim clean across, and the lower control arm. But the leveling kit was perfect.
I've seen 2 or 3 on here bent and at least 2 where one or more of the bolt holes were stripped. I also have a buddy here in Hawaii and he had to remove his because it bent somehow.
I will never put one on my truck nor recommend it, you may have gotten a good one and I hope it continues to work for you.
All good advice. Billet kits aren't any more expensive and the piece of mind they give is priceless.
Reactions: *SocalTitan*
Thanks everyone! I'm gonna check out all of this stuff. I want the 5100s but a leveling kit is more in my budget currently. Does anyone know if it would look awkward if I got the level then didn't get bigger tires. I'm not at my truck now so I can't look at the size but I will post that ASAP
Sent from my Autoguide iPhone app
I'm running a little shorter but wider tire than stock, I think it looks fine, but eventually I want to move up to a bigger tire, most likely a 275/70/18 BFG AT TA
21 - 25 of 25 Posts
