I need a part number for the a/c control head (the unit with the 3 dials) with manual a/c and only if yours has the VBC and NOT the resistor....
I am trying to determine if the control head is different for 2004 titan if you have a VBC or resistor....Mine has a resistor and the part number is:
27500-8s211
It is located on the back or side (drivers side) of the a/c control head (if you pop out the center panel where the radio etc is
Thank you in advance!
27500-8s211
