1 - 20 of 35 Posts
Psycho_outlaw
So on my drive back home to Minot, I was doing about 80 MPH. The truck started acting weird and check engine light started blinking. Stopped at the nearest auto store to check it out, got a p0305 code and a p0300. Which is the #5 cylinder misfire. What do you think could cause this on an 06 flex fuel with 70k miles?
Sent from my XT907 using AutoGuide.Com Free App
Thanks for the help! I hope its as easy as changing plugs
So i am finally going to get around to fix the T. I have a #5 cylinder misfire. My question is, where is each spark plug position? I tried to find a diagram through google but no luck.
Here you go
Posted from my Titan.
I would make sure the connector plugs are tight on the coil pack first.
Next would be to remove the coil pack and the spark plug and see what the electrode on the plug looks like.
You can move the col pack from #5 to #3 and if the miss moves to #3, you have a bad coil pack.
The engine hasn't been wet has it? Water will cause coil packs to do strange things.
Reactions: JB and nightowl
nope no water that I can remember.
What walrus said ^^ Nissan didnt get too happy with the di-electric grease either with the connections. I went through and re greased all my electrical connections I could find.
Discussion starter · #10 ·
Well swapped coil packs and misfire stayed put....bought some new plugs hopefully that will work
Pull #5 plug first and check condition.
70,000 is a little young for plug failure but is is not unheard of.
Discussion starter · #13 ·
Discussion starter · #14 ·
So changed the plugs...still running like doodoo......but plugs didn't look to good either but not horrible
Has to be a bad fuel injector.
Discussion starter · #16 ·
Here's my number 5 plug....they all looked about the same
p0300 and p0305 probable cause(s) ignition system fault, fuel system fault, large vacuum leak, maf sensor fault, AF/HO2S sensor fault or engine mechanical condition this is according to wellsve.com I hope this will help
Discussion starter · #18 ·
I'm throwing the same code as you, P0300, but no other code just the engine misfire detected, which leaves a plethora of issues it could be. I have the updated IPDM board but swapped ECM and fog light relay just to make sure and problem still exists. Heard a vacuum leak today after shutting it off. My next step will be to search for a leak tomorrow during daylight hours.
Discussion starter · #20 ·
I was hoping mine was going to be a simple fix. I still have not got around to fixing mine, since my garage sits at around 0 degrees. Sucks to try and work out there for long periods of time. but since I have 3 vehicles its not a huge deal just yet. but I do miss my baby.
1 - 20 of 35 Posts
