Cornfed 2 1/2" front and 1 1/4" blocks in back installed!
3.5K views 14 replies 10 participants last post by  Jason B
#1 · (Edited)
Wow, great fit, great kit, Cornfed 2 1/2" lift on the Front and 1 1/4" blocks in the back. Easy install, great ride, great feel, great look! J. Burtman and Cornfed come through again! In total,my back sits about 1/4" higher than the front which is perfect for hauling towing etc! Great kit great price...a definite buy for those interested! Thanks again Jason and Cornfed!
Jason can you post some of those pics taken today?
#4 ·
Can you expand on what this means?
"The 2.5" spacers will include an aluminum spacer which mounts outside of the coilover and also a smaller UHMW spacer which requires a coil compressor to install inside of the coilpack. "
So there's a standard leveling spacer, then this extra one? What is it?
#6 ·
Do you have any better pictures of before and after with the 2 1/2 lift kit. The picture shown here looks like there are jacks holding the truck up?
#13 ·
can this kit be used with the bilstein 5100?
#14 ·
bilsteins lift the truck with preload, this kit also uses a spacer to do the same. Bilsteins have been known to bend and break at the bottom bolt location because of too much tension on the shock. I wouldn't recommend preloading the spring through a spacer and the bilstein preload. Just do a normal spacer that doesn't mount between the top hat and the coil spring.
