1 - 12 of 12 Posts
Ready2race
Exaust Manifold interchange years?
I have a 2004 Titan 4x4 I have leaking exhaust manifolds. I found a set of good 2012 manifolds. Will they fit on my 2004? I called a junk yard and they told me the interchange was 2004-2006. Anyone know the difference? Thanks
Re: Exaust Manifold interchange years?
If you are going through the trouble, most go to Long Tube headers and moving the cats after the headers. Even the updated Nissan manifolds seem to fail.
Look up forum member Nightowl, cajunbpipes.com
Exactly what Chad said. The stock manifolds are junk even on a 2014 and the labor involved in the swap is intense and expensive. You will be back to leaks in no time so my advise is put headers catted bpipes and Uprev tune it for a way more reliable fix. Even the aftermarket manifolds are crap and fail not to mention very expensive. The Cajun stage 1 is the best "fix" on the market at the cheapest price. Do your homework before you spend a dime or you will be out a lot of money soon. Cajun Bpipes | shreveport, LA 71129
Yes all the Titan manifolds are interchangeable.
"Nightowl" does that package with uprev include the download cable? Thinking about buying it
Not only the cable but complete support and e-tuning by seymore4 the Cajun tuner. Give me a call and we can get you fixed up. 318-347-6157
Another Titan getting ready to be fixed the right way!!!!! You will love the end result, Cajun Pipes all the way!!!!!
Well this is kind of a depressing thread Im having manifold leaks also.the rest of my exhaust is fine. What would it cost from cajun?
Packages starting at $1385 for everything, but there are different options that can make it cheaper or more expensive. I would shoot Jeff an email or call and see what works for you
Performance-Packages
You will not find a cheaper "FIX" on the market and the power gain is awesome without affecting the fuel economy. Do your research before you spend a dime. My contact number is on the website.
1 - 12 of 12 Posts
