Ok, let's see how many heads explode...
I had my ABS unit get water in it before I ever owned it. This caused some severe issues at times with the it activating at moderate speeds/normal braking. So when it got to the point of not working at all I deleted it and put on a Wilwood proportioning valve and having it completely replumbed. We left the half of the abs valve body attached to the wiring harness so the ECU could 'see' it. Everything is basically fine besides I have too much pressure going to the calipers. (All new calipers, rotors, pads, booster, reservoir) To compensate for this in the interim, I've left air in the lines. I don't drive her far till I either get this issue figured out, or the situation improves with limited driving.
Do any of you fellers have any ideas to share? I've already gotten plenty of haters from the younger crowd, but figure since I've driven more trucks without ABS than with, I should be happier with this setup, lol. Only lights present is the 'brake' light.
She's a 2004 Crew Cab with original engine/ trans. and 209,000 miles. Anything y'all got will surely be appreciated!
