What is the difference between 2wd and 4wd in suspension parts, like shocks, tires etc...... and how do the different parts perform.
I thought he was talking about stock suspension parts..Justintoxicated said:2WD = Spindle Lift
4WD = Bracket Lift.
The Spindle lift is cheaper I think than the bracket lift and gives you a litle more ground clearance. PRG sells setups for both. But that should not determin wether or not you buy a 4x4 or not.
I guess if you figure that tires are a suspension part?AgTitan06 said:I thought he was talking about stock suspension parts..
I interpreted his post that he wants to know what is the difference between the suspension and tires for a 4x2 and 4x4 stock Titan.Justintoxicated said:I guess if you figure that tires are a suspension part?
